I am using Simplify3D with a Cubepro. Everything was going fine and then one day the Cubepro started rejecting the files. I found the fault to be in the first ten lines on the file. When I superimposed the first ten lines from an old file (that works) onto a new file it worked. I used text editor called "NotePad ++" and found that the new file has extra line feeds and carriage returns between each line. (The extra LF's and and CR's are between every line in the file but the files "readablitiy" is only affected by the first ten lines.) See the examples below.
This is the "old" output which works
^Firmware:V1.10 CR LF
^Minfirmware:V1.00 CR LF
^DRM:000000000000 CR LF
^PrinterModel:CUBEPRO CR LF
^MaterialCodeE1:259 CR LF
^MaterialCodeE2:-1 CR LF
^MaterialCodeE3:-1 CR LF
^MaterialLengthE1: 1 CR LF
^MaterialLengthE2: 0.000 CR LF
^MaterialLengthE3: 0.000 CR LF
This is the "new" output which does not works
CR LF
CR LF
CR LF
CR LF
CR LF
CR LF
CR LF
CR LF
CR LF
I don't recall changing any of the settings but something has changed. Can anyone suggest a solution so that Simpliy3D outputs the files without the extra line feeds and carriage returns?
