- Raise3D N2 Dual.fff
- Updated Base Profile for Raise3d N2 Dual with R3D Premium Filament
- (23.97 KiB) Downloaded 598 times
Started with default S3D Medium: currently printing on left extruder only for now...
Extruder
Left Nozzle Tool 0
Extrusion Multiplier 0.94 (for R3D Premium)
Retraction Distance 1.5mm
Retraction Speed
Layer
Layer Height 0.15
Top Solid Layers 6
Bottom Solid Layers 4
Outline Direction Inside-Out (selected)
First Layer Height 100%
First Layer Width 100%
First Layer Speed 50%
Temperature
Left Nozzle Temperature Identifier T0, Layer 1 Temperature 205, Wait for temperature stabilization (selected)
Heated Bed Temperature Identifier T2, Layer 1 Temperature 40, Wait for temperature stabilization (selected)
Cooling
Speed Overrides
(selected) Adjust printer speed for layers below 15 seconds
Allow for speed reductions down to 10%
Scripts
Ending Script
M107
M1002
M104 S0 T1
M104 S0 T0
M140 S0
M117 Print Complete.
G28 X0 Y0
G91
G1 Z20
G90
M84
Other
Default Printing Speed 2400mm/min
Outline Underspeed 40%
Solid Infill Underspeed 40%
Support Structure Underspeed 80%
X/Y Axis Movement Speed 6000mm/min
Z Axis Movement Speed 1000mm/min
Current Medium Setting attached
Note: This is just a base line profile, that uses the correct LEFT & RIGHT Nozzle Tool Index. Will continue to update
