I've had a recent issue creep up that I haven't been able to narrow down a cause.
Had this issue start over the weekend when I was trying to get a file printed. Job got to about 80% and the printer just stopped working. No movement on XYZ and it also stopped feeding. All temps hold stable, the device still responds as I'm able to go into the menu and cancel the job.
I've tried re-creating the print file and re-running (all settings were kept the same) with the same results.
Last night I tried printing a completely different model the job got to about 30% and I had the same result.
To make things stranger, I tried a 3rd model that completed successfully.
The only changes I've made within the environment recently was replacing the extruder nozzle. However, I've ran about 25-30hrs on the new hardware and these issues are just now presenting themselves.
I'm running the latest build of S3D with a slightly modified (extra bottom/top layers, shells and temps) PowerSpec Creator Pro profile.
Any thoughts as to what I could try for troubleshooting would be greatly appreciated and if needed I can gather some logs or something later today when I get home from work
