mash3d
Rough Surface from supports
Hi, I've been getting a rough surface where the support structures are. They come off ok but still leave a bit of a mess. The upper surface is fine. What settings do I need to adjust to clean this up.
By the way this is PLA. I can post the settings if needed.
Image20160712_194044 by michael32766, on Flickr
Re: Rough Surface from supports
There has to be 10 other threads about this exact topic from the last month. See if you can search and find some similar topics.
mash3d
Thank you I appreciate your taking time to answer. I looked at the printing trouble shooting guide and did a search for "Supports". That search unfortunately came back with 98 pages and 972 posts.
I'm trying to narrow it down a bit.
Does the issue come from the Horizontal offset from part or the support pillar resolution?
Thanks,
