Heutinck wrote:are not those values on the machine tab the values read from the printer firmware. I think the offsets in the gcode are the ones from the preferences in the profiles under the gcode tab. also under that tab do you have the update machine settings checked to write the correct values into the firmware?
There is a duplicate setting in the print profile gcode tab (that was previously set to the wrong "default" values for the printer), but adjusting these values in each profile also does not seem to be fixing the issue, either.
edit: the printer is not connected to the computer I am using S3D on, so the firmware in no way could be the issue, as the printer uses the M218 command hardcoded in the gcode.
