Hello,
I received the software from simplify3D about one week ago and a took me some problems to get a working profile. At first I downloaded the profiles from here
viewtopic.php?f=8&t=3113&hilit=tip+of+the+dayand used the dual extruder profile which is a bad untested profile. I encountered two problems an one of them was the line endings as suggested by BaudR8. To overcome this remove the line:
{REPLACE "\n" "\r\n"}
from the FFF settings in the tab Scripts.
The second problem was that the printer started to warm the third extruder before starting te print. To overcome this remove line:
M553 P64000 S600
After doing this the printer started to print although the results was nog very good. With a profile I got from the support I adapted some filament settings and now the prints are better. Still some improvements needed, but it is geting better.
