Hi, I've been using S3D for a few years now, and just recently decided I should learn to use the second extruder on my MendelMax 3. My first object eventualy worked out, but as it turns out what I was doing wasn't the best way. I had created 2 objects to be printed together, and used the dual extrusion wizard. I then ungrouped the two FFF processes, changed the global offset of one of them, and re-grouped the FFF settings. This got my print to work.
Now I'm trying to print a single object, but with one extruder printing the outer layers, and one doing the infill. Now no matter what I do, setting the offset on the process, or on the machine settings tab, I can't get the offset to work. If I change the Global offset I can move the entire object on the build platform (which is way cool BTW) but no matter what combination I use, it seems the individual toolhead offset settings are being ignored. My bottom layers and outside layers are on the right place, but my infill is exactly 33mm from where it should be. BTW 33mm is the distance between my two extruders.
I've tried 33mm on tool 0, -33mm on tool one on both the process, and in the main machine settings with no results.
Has anyone else had this problem? Also I'm using version 3.1.0
