killonious
Multi Processes in one print
Why when you are change printing processes in a single model does it put a top and bottom layer in your model when it switches the process?
Re: Multi Processes in one print
Well let's say you have 2 processes. If you tell the bottom process to have 3 top solid layers, then when that process ends, it's going to have 3 solid layers at the top. Same for the second process.
So if you don't want that to happen, then you need to edit your process settings accordingly.
