P.S. In the picture the left leg fell off, that's how bad the print is. It just has some goopy epoxy on it right now. And yes there was supports under the triangle but the bad quality continues above it for the rest of the 6" of height it has.
You may want to try printing hotter. I think 235-240C may be better. If you have bad layer-layer adhesion it usually means you didn't extrude hot enough. OR you can print slower, which will also help the adhesion. I've never been able to print with that stuff below 225C and get a good stable part.nirakara wrote:Well I think I've fixed it about as well as it can be fixed. Fixing the cad so the internal walls didn't overlap with the perimeter helped quite a bit (I'm looking at you S3D for this one) and I've increased the travel speed up to 150mm/sec and increased retraction distance too to keep it clean. Hopefully putting my notes on here will help someone too in the future.
