I am not able print dual extruders - and after reading through this forum I already learned that offset settings should be done in in FW - so I checked. I am not really good in browsing codes - appreciate if someone could confirm what I found.
Regarding to GerRapRep their firmware should support Dual Extruders and looking in the configuration.h I do find following
// =========================== Configuration for second extruder ========================
#define EXT1_X_OFFSET -2560
#define EXT1_Y_OFFSET 0
and somwhere above
For xy gantry use 2*belt moved!
Overridden if EEPROM activated. */
#define XAXIS_STEPS_PER_MM 80
if I caluclate right this should be 32mm - which is also what I measured.
I am using S3D Version 3.1.0 and created a new dual extruder device using the "other" as Protox V3 which shows up as machine only supports single extruder.
Also uses the Dual Extrusion Wizzard which give me 2 colors in the processes. Temperatures are set at
105C Heatbed
237C Extruder1 (T0)
245C Extruder2 (T1)
Sadly the second extruder never reaches his assigned temperature (in combination with the first), if I just use the E2 as "standalone" it could be heated to what I am setting for it. So E2 is always about 4-7 degrees above E1, independant what E1 is (with the settings above E1 is 236,79C and E2 is 239,82C)
Any ideas please?
Many thanks
Juergen
