The other issue is that the diameter gets wider when the blobs start. You can see how the sides slope out as they go up for the first part.
I tried a negative restart and that helps but the first layers are then no good. The are like under extruded and will fall off.
I used to be able to print this part fine and now I don't know why it changed. I must have forgotten the combo to get it right.
Another thing that is odd is I set the fill to 100% but the preview shows no fill in between the inner and outer wall. If I up the overlap then it shows the infill.
PLA
190 temp
60 bed
