dorsai3d wrote:Your standard infill speed is controlled by the default printing speed. Everything else is a percentage (usually reduction, but can go either way) of the default print speed. So if you want slower infill, slow down the default printing speed.
What else is there?CompoundCarl wrote:You can already change the speed of the infill, outlines, top and bottom solid layers, support structures, bridging, first layer, and rapid movements. What else is there?
So if you need to make adjustments to any of those things, you can already do it from the process settings.
Damn, you're dense....billyd wrote:Uhmmmm exactly what I asked for? Speed control of the non-solid infill !
dorsai3d wrote:like you've seen, you can control the speed of everything (well, except certain parts of rafts, but no one uses those in 2016, right?). It's just that the outline speed is a transition between infill and perimeter speeds.
dorsai3d wrote:Damn, you're dense....billyd wrote:Uhmmmm exactly what I asked for? Speed control of the non-solid infill !
dorsai3d wrote:Your standard infill speed is controlled by the default printing speed.dorsai3d wrote:like you've seen, you can control the speed of everything (well, except certain parts of rafts, but no one uses those in 2016, right?). It's just that the outline speed is a transition between infill and perimeter speeds.
