Printing the ole NCC-1701 and trying a vertical approach to save plastic. Want a raft and obviously have to have supports. But why doesn't Simplify put a raft under ALL my supports?
I think I know why, and it's a bug. There are 3 processes for three segments of this print:
Bottom: raft and supports, 20% infill
Middle (pylons to warp engines): supports, 100% fill
Top (above pylons), supports, 20% fill
Using the instructions from https://www.simplify3d.com/support/arti ... f-a-model/, I've been able to get the fill changes to work. But if you look at the base, you'll see the raft is just 3 circles (under the 2 warp engines and the secondary hull); it seems to have no idea that the saucer is there (I'm sure because the process's Advanced/Layer Modifications says to stop printing before the pylons). However the support generation does seem to know about the saucer and the pylons. Unfortunately the supports start getting printed at the raft height, and there is no raft under the saucer/pylon area.
I've tried telling it to generate a raft on all three process, and also just the bottom process. Same results.
So I'd say that's a bug.
To try to work around it, I've made the raft diameters enormous (even larger than the skirt shown in the attached photos), but there are 2 problems that doesn't solve:
- The biggest is that the support disappears for about 10% of the saucer under two parts of the saucer.
- The second is that the support structure "changes" where the processes change (above and below the pylons), making the support a lot less stable.
Would (obviously) love to see these bugs addressed soon!
