Skirt/Brim does not seem to be affected by the first layer underspeed.
I have difficulty to make it stick. Should it not be printed with the same underspeed?
bapro wrote:I can see that it changes, but the speed is greater than for other areas. Logically, it should be lower. Compared to the raft's speed it´s 4 times as high. The reason for both is to ensure good adhesion to the building plate.
It seems like raft uses the % of outline underspeed while skirt uses the % of default printing speed.
When I print PLA or ABS it´s mostly no problem. Now I´ve been printing PET-T and it´s been more problematic . Would be great if skirt used the out underspeed as well, function would be improved.
