Noticed gcode generated for dual extruder has a tool change every layer, even if the second tool isn't used that layer. Isn't that a waste of code? Makes it tough to add any tool_change scripting if it executes the script every tool change for no reason.
Hmm… I'm not seeing this at all. Are you sure you didn't add a layer change script?
If I use one of the dual extruder profiles in the software and I add a toolchange script, that script is only included when switching between tools. That's exactly what it's supposed to do, and it doesn't happen every layer unless you are switching between extruders every layer (such as a dual-extrusion print).
Bascially, on the layer above, the second tool wasn't needed, yet it still initiated an M135 T1, then back to an M135 T0. The specific part above only required the second tool for about 20 layers out of 80 or so, yet every layer that didn't need the tool, had the above...
