We have a screw extruder that we want to use to produce large coarse prints on a cartesian style CNC machine. The extruder is servo driven to match extrusion rate to print speed.
Nozzle diam is 10mm and the goal is to do 3-4mm layers at 2m/min.
There is a lag between input and extrusion which needs addressing. I see 2 ways to solve this:
1. Either advance the extruder (A axis), or retard the machine moves (XYZ axes).
2. Or (less preferable) forget about trying to match extrusion rate to print speed and just run the extruder at a constant speed and move it around at constant speed too (i.e. no slowing down at perimeters, corners, small radii etc).
Does anyone have any suggestions? Any help much appreciated.
Thanks,
Mike
