Axxis_86
3w file plugin error
Hey everybody!
I have a Da Vinci 1.1 Plus.
I bougt the newest Version of Simplify3D.
I Prepare the print. So far so good. But as soon i Save the Toolpath to disk i get the 3w file plugin error.
What can I do?
Thank you very much in advance for your answer and greetins from Germany
Marc
Re: 3w file plugin error
I have several of the XYZ printers and have never had this issue. Maybe you should post more details. Can you include a factory file (go to File > Save Factory File). Maybe also include some details about your computer hardware and what operating system you are running
Axxis_86
I am using an Asus Labtop.
Intel Core I5
8 GB Ram
GeForece GTX 950
Windows 10
Its a Brand new machine so i doubt hardware issues.
Maybe my settings are not right, but i use the preset for that printer
Do you have a Da Vinci 1.1 Plus?
The Factoryfile is to big so i cant load it up -.-
I've been making 3w files for months on a Windows 10 computer, and I have several friends that do the same as well. No one has ever had problems creating the files, so I doubt you're going to get much help if you can post any files to help others try to recreate your problem
Axxis_86
Here is the File. Ive found a way to uploade it.
http://www.pastefile.com/dLT8V3
Axxis_86
Okay I found the error.... I had to assign S3D to the Nvidia Grafikchip. It was assigned to the "Main GPU" and it was to weak for it.
Still thanks alot for your help guys.
Greetings from Germany
Marc
