We are happy to announce that this feature has now been added in Version 4.0. You can now customize the extruder that is used for the dense support layers, at the interface between the part and the regular support structures. To do this, click "Edit Process Settings", go to the Supports tab, and first make sure that dense supports are enabled by changing the number of dense support layers to something larger than zero (usually 3-5 seems to be a good starting number). Then you can choose the dense support extruder to change which extruder is used for these dense interface layers. So if you had a dual extruder machine with PLA in one nozzle and PVA in the other, you could use PLA for the majority of the regular support structures, and then only switch to the PVA material for the last few dense support interface layers. There is a picture of this technique near the bottom of the page below:
https://www.simplify3d.com/simplify3d-v ... d-quality/
Dissolvable filaments can be expensive, so we hope this will help you save money on your prints and optimize where these materials are used!
