I'm running the lulzbot taz 6 too with lulzbot's dual extruder v2.
Exact same problem here. I added the M218 into the starting gcode, right at the very top
This is my S3D starting gcode
http://pastebin.ca/3721903
This is Cura's starting gcode (default taz 6 dual extruder v2 software)
http://pastebin.ca/3721904
The toolhead offset problem was solved instantly by adding the M218.
However, I'm running into another problem after this
Sometimes, during the first probe (while on S3D), the toolhead misses the z probe (theres 4 bed washers + the z probing button) and goes straight down, damaging the printer.
Here's a photo of the damage caused by the rear nozzle at 170c slamming into the bed corner repeatedly until the printer was manually turned off.
https://www.dropbox.com/s/cfp057urwnsva ... 6.JPG?dl=0
I'm not able to replicate this problem on demand, it happens sometimes, even with the exact same stl, settings and gcode.
______________________________________________________________________________________________________________________________
I understand you recommend updating the firmware with the right offsets thru Configuration.h however, the latest instructions for how to do this for the lulzbot are in 2013, with no information given for the taz 6 as shown here
https://ohai.lulzbot.com/project/firmwa ... -flashing/
The latest firmware files for the taz 6 is here
http://download.lulzbot.com/TAZ/6.0/sof ... Q2/Marlin/
May I know how should I go about?
The instructions said to use Arduino 1.0.5. but the instructions are dated 2013, the Taz6 firmware files downloaded are really different (missing the libraries folder), and etc.
Also, after setting the M218 in the starting script, do I need to set the same settings anywhere else in S3D? I read that the software does not know what the firmware offsets are, and therefore it might affect the tool path planning, although I'm not sure about this.
E.g. set in Process Settings > Gcode > Toolhead offsets
or set in Preferences > Machine Settings > Toolhead offsets
If it needs to be configured as well, does this apply as well if I set the offsets in the firmware instead of thru M218 in the starting script?
