JohnB
Re: Infill Pattern Issue
I've seen something similar to this where every time I re-generated the code, the preview would be different. It had something to do with the .stl file I was using.
JohnB
Try slicing this .stl multiple times and see if it's not different every time.
4 5mm boxes (repaired).stl
(2.82 KiB) Downloaded 257 times
JohnB
Here's what I get slicing multiple times without changing any settings...
