I’m nearing my wit’s end (usually not a long journey), and would really appreciate some help. I print with a FlashForge Creator Pro, using a glass plate for a bed, and ABS juice for adhesion. I’ve been having problems with some prints. I’ve been through the print quality guides on Simplify3D but haven’t yet found the magic formula. I’m printing a simple 10X20X20mm cube that exhibits the issues I’m having. The .STL came with the printer. I print with Hatchbox filament.
My prints have these problems:
• The cube is not a cube. The 10mm sides dish inwards by nearly 0.5mm
• The vertical corner edges are rounded, not sharp
• The corners of the top surface are not flat. They have sharp upwards points.
• The corners of the bottom surface also curve upwards
I’ve worked with bed temps, extruder temps, cooling fan speeds, number of layers top and bottom, filament diameter, and other slicer settings. I can sometimes make things worse, but seldom better.
Here’s the real puzzle to me. The printer came with ReplicatorG. When I slice using that engine, with default settings and the same .STL and same filament and etc, the cubes are near perfect. It’s only when I slice with S3D that I have these issues.
Any help will be greatly appreciated.
LazyWolfe
