3DAli
Makerbot Rep 2x heated tray temp. issue
I have set the tray temp at 130 in the profile setting, however it only goes up to 120 and shows 120 as set temperature! I alway have to correct this using machine control panel after the print has started. any idea of why this is happening would be greatly appreciated.
Regards
Ali
Re: Makerbot Rep 2x heated tray temp. issue
There's plenty of other threads on the forum about this. GPX limits the bed temperature to 120 degrees, so if you try to go above that, it will limit it
3DAli
Regards
Ali
