I am a new user of Simplify3d and am going through learning 3D printing. I have a Prusa i3 which is working beautifully. I have printed several thingies including a geared key chain very well.
I am now trying to design parts (in FreeCad and OpenScad) and am having a funny issue. So I created a 20x50x10mm bar. I then added a 5mm in diameter circle, a 5mm hexagon (each side of the hexagon is 5mm) and an equilateral triangle (each side is 7mm) and I then pocketed each of these shapes into the bar (5mm).
I then printed 3 cylinders (5, 4.8 and 4.6 x 10mm), 3 hexagonal bars (5mm, 4.8mm and 4.6mm x 10) and finally 3 triangulars bars (with sides 7mm, 6.8mm and 6.6 mm x 10).
After printing the holes are not the original sizes!!! So I can fit very nicely the 4.8mm cylinder in the circle, the 4.6mm hex bar into the hexagon and the triangles dont fit at all
My settings are sort of normal for PLA.
All settings in mm:
PLA 1.73mm
Nozzle 0.4
Extrusion multiplier 1.06
Extrusion Width 0.48
Layer height 0.2
Top and bottom solid layers 3
Outline/Perimeter 3
Infill 20% Rectilinear
No support
198 deg C hot end
64 deg C bed
Hot End and Extruder fans on
I am looking to print some enclosures with pins to go into sockets for locking it and cannot get the sizes right...
Any help would be greatly appreciated.
Many thanks,
D
