Hello,
I was printing some large prints with a very high level of success for about a week after upgrading to an all metal hotend. I did a few small prints and opted to use the "Vase" print setting because I was just printing some small rings. It gave me a message that it would override some settings and I clicked ok.
Now that I'm back to trying to print large items I've removed the "Vase print" setting and everything appears to be setup as it was prior to this change. however regardless of what my infill % is 35-100% after the first layer the print seems to get stringy and not really bond to the previous layer.
Heat seems to be fine I don't see temps dropping on the extruder more than a few degrees.
Printing Inland PLA with MicroSwiss all metal hotend and .6mm nozzle
100% infill from 0-2mm
50% infill from 2mm to finish
extrusion multiplier set to 1.10
extrusion width set to .7
extruder temp set to 225 c
bed set to 60 c
print speed 5000mm per min
It was working fine prior to that little vase printing experiment I tried and I've even uninstalled and reinstalled the application and I've created a new STL file just in case something was cached/corrupted.
Any thoughts would be appreciated!
Thanks!
