If you can, I'd strongly recommend to use some memory device instead (SD-card, USB-stick, whatever your printer takes). Printing tethered is usually a bad idea for a number of reasons.
I doubt S3D has made any changes pertaining to this, but if you can use a memory device you will eliminate this as a source of failure.
