Recently, my Simplify3D (version 3.1.1 running on Mac OS Sierra 10.12.1) has started resetting the build volume to zero.
That is, if you open the Simplify3D Preferences panel and click on the "Machine" table, the dimensions for the X, Y, and Z axes are all shown as "0.00" mm.
I notice this when the program claims that I can't print a model because it exceeds build dimensions.
I can go through the configuration assistant and re-select my machine (Makergear M2), but it's getting annoying. Is there something I can do to fix this?
