Wheazel
Skirt/brim around single objects in multi object print?
Hi
I am having problems with printing large amounts of small objects in ninjaflex. Due to the nature of this material, its hard to prevent oozing.
Therefor the start of each new object will have to deal with a blob thats partly set. If I could make sure that every single process starts with a brim, this problem would go away. Unfortunately I can't it seems. Regardless how I set it up, the software makes the brim around the entire printarea. If I reduce the distance and space the parts, the program still prints all separate brims before starting the first part. This makes no sense as the printjob is set up as a sequence. (Pain in the A** to do in S3D compared to Cura or Slic3r)
Why these obvious shortcomings in a software that has some really sophisticated functions overall?
Wheazel
Re: Skirt/brim around single objects in multi object print?
I do have to adress some of this topic start. I did manage to get the software to print a brim around every single new object in a sequence print.
Do not know why I didnt manage to make this work at first. Maybe I had a process in the end of the process list with all parts selected or something.
Regardless I got it to work, now I "only" would want a more refined way of setting up prints for multiparts one by one. And have the ability to print infill before perimeters/contours/walls.
