Hi Kumpel,
it is very easy!
You need support (check on the box, open the Support-Tab)
S3d offers 2 possibilitys : automatical and manual Support
For the automatical version, there is nearly nothing to do, the 1 mm column is given.
The printers, the kind of material and even the material spool to spool are very different to handle. Just try it!
For beginners it is obligate to read this:
viewtopic.php?f=8&t=2367
and when there are problems, read this:
https://www.simplify3d.com/support/prin ... eshooting/
but it is strongly recommended to beginn with "Test-Cubes" and "Thin-Wall-Objects" e.g. to learn and collect experiances. Your project is very ambitious.
Here:
https://www.simplify3d.com/support/ and also in YouTube you will find a lot of informations and videos to solve any problems.
If wished, you can send me a PN
horst
