lassehknudsen
Robo3D R1 Plus settings
Greetings,
is there a guide somewhere that shows how to use the Simplify3D with a Robo3D that has autoleveling? I would like the same ease of use as with mattercontrol, atleast for starters.
I coould start the print from mattercontrol, but the problem is that it was midair printing, so the result was not what is was hoping for :)
Searches for this has yielded many possible answers, but with older posts, im not sure if i can trust them.
next, how do i stop a print from the Simplify3D gui, i could not find it.
-lasse
Re: Robo3D R1 Plus settings
I think you can just go to Help > Configuration Assistant and load their stock Robo3D R1+ profile. Shouldn't need to do anything else.
As for stopping a print, if you go to Tools > Machine Control Panel, you have a lot more options for monitoring and controlling the printer
njpl
Same issue here. I tried what Compound Carl posted, went to Help > Configuration Assistant and chose ROBO 3D R1+, but I still get the mid-air printing on job start. I'm pretty new to this, so I'm digging for any suggestions on how to get S3D to accept the auto leveling settings from the R3DR1+. Thank You.
dorsai3d
Try the couple of things at the bottom of this thread: viewtopic.php?f=9&t=6336
