Hello,
Can you please add an option to set the first layer height to a fixed value (like in Cura or RepetierHost) as alternative to the relative height (xxx %)?
I already had to re-start several prints, because I changed the quality setting and forgot to adjust the first layer height. Alternatively it would be ok to link the settings of the first layer to the quality settings completely.
Also can you please add a general layer height check to prevent layer thicknesses greater than the nozzle diameter or at least put in a warning?
Thanks!
