I have a Mac operating a XYZ Da Vinci 1.0 over USB. I'm still a bit new to Simplify3D.
Every time I start up the 3D printer, Simplify3D defaults to the wrong serial port, and I have to manually change the port in the Machine Control Panel each time.
There are just two ports on the list. S3D defaults to /dev/cu.Blutooth-Incoming-Port, when it should be /dev/cu.usbmodem14321. I've looked around at where I can change this default but there isn't anything in Preferences or Firmware Configuration. Any ideas?
