SHoutzager
Printing the tip of a pyramid
This has happened to me a couple of times. I will have something that has a point at the very last part of the print and that point will not print. Simplify slows way down for the point and printer will clog or just not print the last 1/8". Maybe I should keep the speed constant. thanks.
https://www.dropbox.com/s/hdnulje6b03r6 ... t.jpg?dl=0
dorsai3d
Re: Printing the tip of a pyramid
It's also possible that your printer's buffer gets overridden when you get to the end of a print - I've seen some printers that do this. Try adding M400 as the first line of your ending script.
You can disable the "adjust printing speed for layers below XXX seconds" option on the Cooling tab if you do not want the speed to reduce
SHoutzager
Thanks, will give both of those a try.
