malamber
Unhandled exception repairing manifold
Hello,
I'm brand-new to simplify 3-D, but I've been a very long time software developer.
When attempting to repair the manifold of a particular simple model that I have, simplify 3-D crashes with a uncaught exception. Happens every time for me. Can someone please verify the behavior with the file I have provided?
-- Scott
logo.stl
(487.03 KiB) Downloaded 117 times
Re: Unhandled exception repairing manifold
S3D-Repair is not very efficient but even netfabb fails (https://service.netfabb.com/service.php)
Repeat drawing.
horst.w , GER
http://www.Makeprintable.com also fails to repair this .stl
arhi
that file is very "wrong" :(
the hole top part is inverted and is not connected to the bottom part except in few points only. this looks like a very bad executed boolean between two objects .. you can try to import into some mesh editor (art of illusion for e.g.) and manually fix this but comment in the file states it's made by openscad, you probably have a source so try a different approach in making this STL, maybe report a bug to openscad developer with what exactly did you tried to do.. maybe it's a bug in openscad ...
were you embossing image on a cube or ?
Embed M117 codes into G-Code
open source and unlicence
