having some weird situation that I don't properly understand.
initially my firmware (smoothieware) was incorrectly set ('cause of a typo) to not use volumetric E .. I calibrated s3d with such wrongly configured firmware and I was getting good results (very precise). then I moved to use 3 other slicers and I had problem there (on all three) that I was getting way too much plastic out with "normal" settings and trying to figure out what was wrong I found out my smoothieboard was not using volumetric at all (filament diameter was set to 0)...
I reconfigured smoothieware properly to know that filament is 1.75, nozzle 0.4, proper steps per mm and with extruder multiplier set to 1.0 (in not s3d slicer, 3 of them) I was getting precisely printed parts .. (not as precise as with s3d but let's say properly calibrated parts, 0.400 mm was was 0.40x mm, 0.900mm wall was 0.90xmm I find that precise enough, but some things that s3d figured out some of them didn't so hole sizes were just bit too small etc..) ...
now I returned back to s3d 'cause while slic3r has great adaptive layer feature I need to print a precise part and I need support, and there's no better slicer attm then s3d for precise part and support... and well, as expected, my old profiles now don't work as now firmware has volumetric on... so I (without touching the firmware since I believe it works ok) started calibrating the s3d and I'm super confused ... I get proper wall thickness with extrusion multiplier 2.41 ?!?!
I need to fiddle with it bit more but this makes no sense to me ?!
g-code options
- 5d firmware (include e-dim) is on
- relative extr. dist. is off
- allow zeroing of extr. dist. is on
- use independent extruder axes is off --> maybe this is a problem? but this is a single extruder system so ..?
- include M101/102/103 is off
- firmware support sticky is off
- apply toolhead offsets is off
anyone have any ideas? the print looks ok with this 2.41 multiplier but I don't get why so high
