Support seems to think this isn't a memory leak so I figured I would post here to see if anyone else has come across this.
Here are my specs:
Issue Details:
Simplify3D ver 3.1.1
OSX El Capitan Version 10.11.6
MBP with 2.3 GHz i5
16GB of memory
256GB SSD with 100+GB Free
S3D has been randomly stopping and I get a popup from the OS stating I ran out of application memory. If I look at the resources being used simplify3d will be up to about 12+GB when this occurs, the pagefile is full too at 24GB. Sometimes I can resume a few times then the memory usage drops down to something normal, usually around 1GB-1.5GB, most times I have to kill the application. The page file nearly instantly zero's out once S3D is dead.
It happens at random times, I've tried restarting the printer and the laptop before prints to clear up anything I could in memory but the issue could randomly happen on a Benchy after 20 minutes so that doesn't seem to help.
I've watched the memory climb up in front of me from 1GB to 10GB then go back down again without issue over the course of the print so it looks like this issue occurs multiple times per print but every now and then I get unlucky and the app just asks for too much memory and then blows up.
Also,
This issue does not occur with repetier or cura. I can print for days with them and I don't have an issue.
Any insight you guys have would be great. I've been worried leaving my printer alone with S3D because when it hangs like this the extruder and bed stay stuck on for hours on end until I come back down to my basement and see the app hung.
