So I'm having some bad seam/z-scarring on S3D, have been playing with all kind of settings for two days now without any note worthy improvement.
Then for the hell of it, I thought I just try Slic3r instead. And to my joy/dismay it's tons better with slic3r, even with the exact same settings. Or as best as I could match them. For some reason though Slic3r only gives me 1 perimeter even though I'm asking for two, not sure what's up there.
I was wondering if anyone could possibly look over my settings files and see if they are truly the same or I'm missing something?
I really hope it's a setting issue, because I love S3D in all aspects but those seams are horrendous. And kinda sucks spending a lot of money and getting better results with a free software, as of now anyways.
Setting Files: https://drive.google.com/open?id=0B5qau ... 0NjMV96XzQ
Edit: Looked over the setting files, they don't match completely. Did a little tweaking in slic3r since the seam would just be pin holes on default settings. And had to up the mutliplier by 0.01 in Slic3r to get solid layers. Kinda weird. Default Slic3r, pin holes no blob. Default S3D, divot and blob.
The blob is at start of the layer. Tried No retract, 0.8mm at 80mm/s, 0.8 at 20mm/s with default jerk and acceleration (its a rigidbot, default is really low). Tried same retract settings with over doubled acceleration and jerk. Try with wipe, from 0.1mm-5mm, Coast from 0.05-0.20. Negative restart distance (that just lead to holes and bad first layer). With forced retract on layer change, and without. And countless combinations of the values mentioned. Nothing seem to do much at all.
Best print so far with S3D is pretty much default ooze/retract settings. Just turned off Only retract over open spaces.
Print settings:
PLA @ 190c/60c
speed: 60mm/s
It's really hard to get clear pictures especially white, but you can see the difference. Also the divot is deeper and the blob bigger on S3D print. By quite a lot and not as neat. I'll try to print in another color so it shows better in pictures.
Pictures: http://imgur.com/a/9b0cL
Thanks in advance for any tips!
