SteveIsHeer
Heatbed indicator in machine control panel
Just recently the little red virtual LED that brightens when you turn on the heat bed, has quite lighting up. The heatbed turns on and temp is reported back to S3D and the Viki2 LCD also shows the heatbed icon active and temp rising.. Anybody have an idea why this would happen? It doesn't affect the ability to use the heatbed and print but a little annoying if one uses that as a quick indicator whether the heatbed is on or not.
It show's to go you how feelish you fool when your tang is all tungled up and you bart stalking tackwards!
SteveIsHeer
Re: Heatbed indicator in machine control panel
This seems to have fixed itself after uninstalling all the previous versions of S3D that were not automatically removed when I updated to the latest versions. That begs the question as to why the installer doesn't either upgrade the existing install or remove the previous version prior to installing the newer version. I certainly don't need 3 different versions of the software on my PC consuming valuable SSD drive space!
