joestefano
Filament jam
My filament is jamming while printing the attached model. I have printed it twice and it jams at the same place. I'm thinking that the distance of travel between the square posts is allowing the filament to cool and jam. After canceling the print the jam is easily cleared by retracting and extruding a couple of times. What setting can I adjust to help with this issue? assuming my theory is correct. I am using a direct drive extruder setup. PLA at 230C.
Duet Board Mount.fff
(16.37 KiB) Downloaded 373 times
kabali16
Re: Filament jam
joestefano wrote:My filament is jamming while printing the attached model. I have printed it twice and it jams at the same place. I'm thinking that the distance of travel between the square posts is allowing the filament to cool and jam. After canceling the print the jam is easily cleared by retracting and extruding a couple of times. What setting can I adjust to help with this issue? assuming my theory is correct. I am using a direct drive extruder setup. PLA at 230C.
Check and lower the retraction distance. Which printer is this ? What hot end does it use ? PLA at 230 is pretty high. possible heat creep
Kabali daww!!
Prusa i3 | Kossel
Simplify3D | Cura | Repetier Host | Octoprint
Re: Filament jam
If you are at 230 for PLA and moving a long distance without any extrusion I think heat creep is suspect. Also retraction settings to long and to fast can add to it.
joestefano
Re: Filament jam
This is a CubeX printer converted to Duet electronics. I am using E3D hot ends. I normally print this PLA at 210-220 I raised it to see if it would help. Can you take a look at my FFL and suggest retraction changes. How do I combat "heat creep"?
kabali16
Re: Filament jam
As long as the e3d is assembled correctly, it will not cause any issues. Is it the genuine or a cheap clone ? Is the hotend fan running continuously ? Is the direction of the fan (physical) set correctly ?
Sure, post your FFF.
Kabali daww!!
Prusa i3 | Kossel
joestefano
Re: Filament jam
I may or not have done a stupid thing. I installed my heat break into my heat sink with thermal epoxy (original E3D hot end) I now have a heat creep problem on 1 out of 5 hot ends. Thoughts????
