I just started experimenting with this software for the first time this evening. I've noticed a problem where during the startup routine for a print job, the nozzles are in a position at the edge of the built plate, and when it purges, the melted filament runs over the side of the plate. Is there a way to adjust the start position of the nozzles during the warmup initial warmup cycle? Also, in the software that came with my printer, during the purge step, it would move the nozzles so that the blob of melted plastic wouldn't stick to the nozzle when it moves to start the first layer of the print. Is there any way to add that to the startup script, so that it basically spreads the blob of plastic across the corner of the build plate to spread it out a bit? Sorry if that sounds bit silly, I may not be describing it very well.
