NosIreland
Missing part after slicing
Hi all,
For some reson after slicing I get missing parts in 3 d model. See pictures below:
Model
Sliced
Slic3r seems to work ok
Any explanation for this?
brian442
Re: Missing part after slicing
You are already tell just by looking at the model display in S3D that there are a lot of problems. Looks like lots of self-intersecting surfaces and backwards faces. So you can pretty much guarantee that this is not a valid solid model.
So I would say either fix the model in the original CAD package first or maybe try to use one of the free repair services (netfabb, makeprintable, etc).
kabali16
Looks like some triangles are flipped. Go to Repair menu, click on Flip surface orientation and select the face on the model that looks inverted. This should fix it. As a test, Click on View normals on the toolbar. All the Normals should be facing outwards.
Kabali daww!!
Prusa i3 | Kossel
Simplify3D | Cura | Repetier Host | Octoprint
