larod241
Profil for UM2+
Hi all,
Can someone share his optimized profil for UM2+ with 0.4 nozzle and pla please ?
I use standar profil, but it's not realy good (blobs, ...).
Thanks a lot
Regards
brian442
Re: Profil for UM2+
I imagine there is going to be a lot of variance just based on what filament you are using, so I wouldn't be surprised if you still need to make a few adjustments even when using the stock profile. I would suggest starting here if you're having trouble with blobbing: https://www.simplify3d.com/support/prin ... s-and-zits
After you work through those suggestions, if you're still having trouble, post some pictures of your prints so that others can help more
PinballGeorgio
Re: Profil for UM2+
At your service.
Standard profile was not good for nice prints.
PLA_Ultimaker2.factory
(2.85 KiB) Downloaded 370 times
larod241
Re: Profil for UM2+
Thks a lot ! i'll go to test it now !!!
Regards
PinballGeorgio
Re: Profil for UM2+
Let me know if the print is better with this settings
larod241
Re: Profil for UM2+
It's a lot better for me with neofil3D pla !
I'll go to try a Benchy boat !
Thks !!!
2
1
1
