In Windows 8, adding Simplify3D to the Start menu means that when you run Simplify3D the operating system automatically builds a list of recently opened factory files, which are accessed via the Start menu option.
Unfortunately, Simplify3D doesn't support command line options - so those links to factory files do not work.
I would therefore like to request that Simplify3D is modified so that a command line specifying a factory file can be supplied.
Furthermore, in most regular applications the File menu contains an option listing the most recently opened files, making it very easy to reload a recently worked on project - without having to navigate thru Windows Explorer to find the file of interest. I would therefore appreciate it if consideration could be given to recently loaded factory files being shown shown in the File menu.
