Hi all,
First post. I have just bitten the bullet and brought Simplify3D after umm-ing and err-ing for a while. After just having two 4 hour prints fail due to an apparent slic3r induced Y-skip (both in exactly the same place, no apparent mechanical or electrical issues, other prints have passed this height fine etc) I finally got sick of it and decided to give Simplify3D a try.
I started with the default Prusa i3 profile and have added a new material profile for PETG which is the material I use 99% of the time. I have made minimal changes based on my 'working' slic3r configurations - simple things like bed area, G29 added to startup code, temperature set, manual extrusion width set to 0.5mm.
Generally when I get a new filament I print off two pieces which help me to tune, the extrusion multiplier. The pieces are a 2-euro coin calibration piece and a single wall tower.
The two euro test piece printed very well (considering a new slicer and I've done no tuning at this point) the coin doesn't quite fit so I think I'll need to reduce the extrusion multipler a little compared to the one I had set in slic3r.
The single wall test piece didn't print at all. The skirt printed around where the object should have been but that was it, not even the first layer of the object went down. This is exactly as shown in the preview - the object doesn't appear.
What gives? Any pointers on what I need to do here?
The STL of my test objects are here if that helps:
https://gofile.me/2yg11/KmFFixFLe
https://gofile.me/2yg11/dACj1I1Q5
