Want to make sure I have this right.
I calibrated my setup so that .90 multiplier @ 1.70 filament diameter @ .4mm manual width does in fact give me .4mm width extrusion when printing a single walled square.
Now, when I print that square with full fill, the top layers show some gaps. If I increase the manual width to .48mm, S3D will
a) extrude more filament per path traveled?
b) space out X and Y back and forth motion a bit more anticipating a .08mm increase in line width?
c) both?
I assumed both, so I tried it anyway. The gaps seemed to have disappeared, except I assume now my holes will be a bit smaller due to thicker layers.
Are these assumptions correct?
