OK, So I've been using S3D for a while now and I should really understand how all this works, but I don't.
Also, I spent some time reviewing past posts but did not see this addressed directly.
The only way I've been able to get dual extrusion to work is by sheer determination!
So I start with the Dual Extrusion Wizard and pick a profile.
1. There is drop down menu for "Material Configuration." Why is there ONE material selection when setting up DUAL extrusion? You will definitely need two different material settings- even if you use two different colors of the same material, the pigments can change the properties, so shouldn't there be a material setting for each?
2. Still in Dual Extrusion Wizard, in the Base Profile Template pull down, well, sometimes it shows all my Profiles and sometimes it shows only the Dual Extrusion Profiles. In the cases where it shows the single-extruder profiles as well, selecting one gives a message that I must select a Dual Extrusion profile.
However, I can then go into Edit Process Settings and select Single-Extruder profiles. Needless to say the Dual Extrusion won't work with two Single-Extrusion profiles selected.
3. Then I go to "Edit Process Settings" which brings up the FFF Settings menu for the selected process, lets call it Color 1.
Under "Auto Configure for Material" I select ABS, and make changes to the Nozzle Diameter. Now that nozzle setting is changed under all the materials - PLA, Nylon, etc. What is the point of even having a material selection if any change to one changes all the others?
4. Now, if I jump back up to "Auto-Configure Extruders" I would think that you would set the Color 1 process to Left Extruder and Color 2 process to right extruder, but that didn't work right, so it has to stay at "Both Extruders." Again, not sure what the purpose of this is.
5. Then there is more confusion in Temperature Settings. So there are two processes, Color 1 and Color 2. They both have independent settings for Extruder 1 and Extruder 2 temperatures. Color 1 uses Extruder 1 and Color 2 uses Extruder 2. So under the Color 1 process I set Extruder 1 to 200° and Extruder 2 to 0°. I go to the Color 2 process and set Extruder 1 to 0° and Extruder 2 to 220°, but when I tried to print, Extruder 2 was trying to print at 0°. So I set both extruder temperatures in Color 1 and THAT worked!?! So does it only look at the first process for temperatures?
If it pulls all the settings from the first profile anyways, then why the need for a Dual Extrusion profile to begin with?
I could continue, but, I'll leave it at that. Any and all input, recommendations, and explanations are appreciated!
Thanks,
Innovatorator
