joestefano
Start script help
I have 3 extruders, Duetwifi controls. Is there code I can enter in my start script that will select the extruder that is being used? The "T" is variable can code be written that will alter the code depending on which extruder is chosen similar to the M109 [xxx] Now I have different start scripts for each extruder. It gets a bit confusing.
G1 X245 Y270 F4000 ;Move to purge bin.
T2
M109 P2 S[extruder3_temperature] ; Wait for extruder current temp to reach
G1 E50 F200 ; Purge E(xx) and F(speed)
kabali16
Re: Start script help
I think you have it right. T# selects the respective toolhead. What firmware do you have running ? I see you are using P commands in M109.
Not sure if you have read this forum post, but it does give some useful info -> viewtopic.php?f=8&t=1959
Kabali daww!!
Prusa i3 | Kossel
Simplify3D | Cura | Repetier Host | Octoprint
joestefano
Dc42 reprap for duet board
