raffo333
Calibration parameters
Hello, i am trying to calibrate my printer (wanhao 4x) as per this article
http://www.thingiverse.com/thing:52946/#instructions
But as a new user i need you help
Can these parameter be changed in simplify3d ?
Carve/Extra Decimal Places (float) : change to 5
Carve/Edge Width over Height (ratio) : nozzle diameter/layer height
Inset/Infill Width over Thickness (ratio) : nozzle diameter/layer height (initially)
Speed/Flow Rate Setting (float) : needs calibration
Scale/XY Plane Scale (ratio) : needs calibration
Regards
Raf
JBFUK
Re: Calibration parameters
Did you ever find your answer to this?
