I have a problem with non touching perimeters.
I have an object with 4 perimeter shells. I print from outside to inside.
During printing I can see that only the 1st and 2nd outer perimeters touch well. The 3rd and 4th have a gap.
What I can observe is that the outer most shell is printed slowly and for each further shell the speed gets increased - this causes the gap.
But I cannot see any setting to avoid increasing speed for shells.
What I did now is I increased temperature and extrusion multiplier - then the gaps are closed but then I have too much filament in other areas of my object.
Why S3D increases the speed for outline shells if it moves inwards (if printing shells from outside to inside)?
What can I do now?
