You have create a cross-over intersection in Bottom> Dome (0.2) and Slice (0.1).
That is not possible. In the horizontal level S3D accept only one layerhigh. With Dome (0.1) you get a print, but you are running into the bug as written above: the pillar and the ooze-shield are only available for the first 5 mm. (pic 1)
Delete the Top and inside Bottom > Dome and > Slice the LayersModifications (Advanced-tab) (<> 5mm) and your model will be print as expected (pic 2)
You have positioned the pillar to NE but Slice is laying in E-direction. I think it is better to coordinate both to NE or both to E or other directions, because the printhead of your printer is than not needed to cross Dome#Slice or Slice#Dome.
horst
