Hello guys, I just wondered about two features/issues while trying to print two colours, same material (PLA) with a dual extruder (E3Dv6) with an offset on X-axis of 26mm.
1) Once I tried to set the offset of 26mm under "Edit process settings" --> G-Code tag:
Toolhead offsets: Tool 0 --> X=0, Y=0
Toolhead offsets: Tool 1 --> X=26, Y=0
the generated G-Code file make the second colour 26mm apart on right side of what it should be (over the first colour printed). How should I configure it?
2) As known, ooze when using two extruders can be minimized dropping temperature of the not-used hotend, while the other one is printing. Is there any feature of this temperature drop?
Many thanks!!
